[SIZE=6]SOLD[/SIZE]
*08/02/2012 just got the vehicle inspected today and is good till 08/02/2013
Price drop $4500
Car is located in Roanoke VA. Pictures were taken in 2011 when I bought it But the car looks the same but lowered a small amount. The pictures are with the oem suspension. The car currently has Tein Supper street coilovers on it. The motor has 18k car has 300,200k as of 06/18/12. Newer pictures have been taken as of 4/11/12.
The following things have been done.
New Engine: balanced and blueprinted
B16 sleeved block, 1.7 Crank shaft, 1.7 Rods, Factory 1.6 pistons (.25 over), B18c1 head with ITR cams, new valve guides.
Transmission: Recently rebuilt with all new bearings
New Clutch, timing belt, water pump, tires, upper front control arms, front brake pads and rotors, rear brake pads, axles, 4 wheel alignment, Skunk2 intake manifold, catalytic converter, DC header.
Everything on the car works and I wouldn’t hesitate to drive the car anywhere. All it needs is a new driver. The original B17 block head and suspension will be included in the sale if desired but are located out of state. $4900
http://www.youtube.com/watch?v=G9XazadNOrc
http://www.youtube.com/watch?v=XW7A9mUL4UA
