1995/1996 jdm ITR help
I have a 1993 db1 that a couple of weeks ago I put suspension and wheels from a 1996 jdm only Integra type r. After putting the new wheels and tires on I drove it around for a while and the driver side wheel was making noise so I felt it and the wheel bearings felt loose. I then took the spindle apart and took it down to a machine shop to have them replace the bearings but they said the hub was bad. So my question is where can I get a new hub since that year never came to the U.S. The only place I found wants 150.00$ which I thought was a little pricey. I was also wondering if anyone knew if the wheel bearings are the same as other 1996 Integra’s, and any other details about this swap.
Note: the 1995/1996 Jdm ITR had a 4 lug bolt pattern not five lug like the 1997 and up type R’s but the four lug was bigger than the U.S. Integra which made it the same pattern as the Honda Accord which I believe is 4 114.3
You probably got unlucky and got a suspension that had bearing that where on the way out. Unfortunately that is the lease of your problems. The real problem is that is sounds that you bolted the stock DC2 spindle on the DA and that is a :tsk: . The DC and DA front spindles are different hence you are throwing the front suspension geometry off. What you are basically are trying to do is the 5 fug lug suspension swap but using the 4 lug version of the type R.
