1st gen b16a in a 92 Gs
helping out a freind.
i did some research but i still have some questions.
The engine is non obd and the car is obd1.
What do i have to do to get this engine running.
i know i will have to use the stock injectors and the stock distributor but what about the ecu. will a chipped p28 to dohc vtec work?
what wires do i have to add for the vtec. i know the wires for the 1st gen in a non obd car but never did this before.
Your help is greatly appreciated.
90ls
erassi@hotmail.com
go to the teg tips, go to the Engine section, download the engine swap guide. Dan (G2Guru) wrote the guide and its essential reading for anyone planning a swap. He also just recently compiled an engine rebuild guide.
:slight_smile:
I done it , u need to use your odb-1 injector and distributor from your old b18a odb-1 motor and get a odb-1 sir ecu !
Re: :slight_smile:
all info easily found in the engine swap guide. (there’s more too!)
i dont have excel so i cant find the ecu pinouts can someone help me, rather then refering me to the guide…
90ls
Originally posted by 90LS
[B]i dont have excel so i cant find the ecu pinouts can someone help me, rather then refering me to the guide…
90ls [/B]
do yourself a favor and the program which will allow you to view excel spreadsheets: http://office.microsoft.com/downloads/2000/xlviewer.aspx
I had to do the same thing, its easy.
also, do a search. in one post dan went a little more into detail about how exactly you go about doing the wiring.
thanx 91integGS.
i dont have a pr4 or a p72 i have the original pr4 which is not vtec i also have p13 and p08 and both are vtec will they work?
90ls
[B]thanx 91integGS.
90ls [/B]
p13 and p08… what are they from, i’m not familiar with those. read the swap guide again, Dan mentions all the ecu’s you can use… and i don’t think p13 or p08 are on it.
you will want a p61, p72(chipped), p28(chipped), or obd1 pr3… i’m pretty sure those are your only options. Oh, if you have the right kind of pr4 you can have it chipped and converted to vtec.
