I have a 90 USDM Integra with the JDM b16a(cable tranny). My throttle possition sensor went bad, and I want to buy a bigger and better after market throttle body, but nobody lists any parts for my motor, I guess because it’s JDM and not common here in the US.
Does anyone know what other motor that the throttle body is compatable with? Thanks for the help everyone. And please only post if you know for sure.
l8er
John
look for parts to a 94-97 dohc vtec del sol, the parts should fit!
:burnout:
a TPS from a LS motor will work as well, they are all the same.
That’s correct.
thanx
thanx for the help!! hope I can help you guys out sometime in the future.
Do you know if the throttle body it’s self is the same too?
l8er
John
Re: thanx
l8er
John
YES it is…
dont waste your time
I accidentally poked a hole in tps, when installing a ignition box, purchasing a aftermarket 7mm bore costs $600 wit an estimated 1 hp gain… go to the scrap yard like i did. $70 cdn
Originally posted by LeftCorner
That’s correct.
so a 94 ls throttle body will work on a 90 integra? Because mine’s going out and i have 94 throttle body laying around.
