I was told that you can use a distributor from a 90 integra , provided you knock off one of the mounting legs so it fits…
Is this true will it fit the jdm B16A? Please help… my car is down!!
yup, it’ll work. but if you have a 90-91 teg you might should just use the distributor that comes with it (both are non obd), unless of course its broken or didn’t come with the engine.
do you have to do any modifications! to make it fit
just like you said, knock off one of the “legs”. I’ve never done it before, but tons of people have. just compare the b16a dist to the ls one, and make the modifications necessary.
does your b16a dist not work or something?
