Morning everyone,
Been a while but I’ve been watching you guys. Any-who, our beloved 03 TL is experiencing a problem that several mechanics have been unable to diagnose. I’ve heard everything from bearings to the power steering pump and no one is willing to take any more of a look than pulling the tire off. The problem is a strange ‘noise’ at this point and as far as I can tell nothing mechanically is wrong with the car. The sound is very similar to that of an old washing machine on a spin cycle with an unbalanced load but turns into a grind similar to the brake dust shield rubbing when you make a right hand turn.
I do have a YouTube clip I’m currently uploading and will link to that once it’s done but in the mean-time; so far this is what I’ve gathered.
*EDIT:
//youtu.be/nzVjtmeATxU
http://www.youtube.com/watch?v=nzVjtmeATxU
1.) It only happens after driving for at least 2 or 3 miles
2.) It gets worse/louder with time/mileage and speed
3.) It’s definitely coming from the front passenger side wheel well area
4.) It only happens when you let off the accelerator
*after driving on the freeway you can hear the noise while on the accelerator only if youre going over 45mph
5.) It doesn’t matter if the car is in gear or out of gear
6.) No sound if the car is jacked up and you spin the wheel by hand, regardless of orientation
7.) We’ve jacked the car up on a lift and run it up to about 40MPH with no sounds emitted, again, regardless of wheel orientation
8.) It’s not the brakes and/or brake dust shield
9.) Neither CV boot is ripped/torn but I’m leaning toward the grease being worn out and this being the cause…
Any help and /or ideas is appreciated. We’re pretty sure we’re going to get the axle replaced at this point but we dont want to just throw money down the drain either
TYAIA
