215/45/16
anybody running this size tires? any rubbing issues? thanks
I know they’re a few DA/DB running that tire size, but it really depend on the offset of the rim, drop and camber angle.
I am running a +33 16x7 rim, -3* front camber and -3.5* rear camber, with a 225/45r16 Toyo R1r. Was running same rim with -2.5* front camber and -3* rear camber with a 215/45r16 RT615.
^^ thanks for the info. i think my rim offset is +35, as for lowering im almost tucking the tires. im running 205/45/16 right now
Running 215-45-16 on a 16x8 +38offset. Camber is 2.5 degrees front 1.3 rear. Lowered 2ish inches with rolled rear quaters no issues.
so i guess im save with out rolling the fender or rear quarters? and with out negative camber? thanks
215/45/16/+43, No rubbing issues although I run 650lbs X 850lbs springs.
Can’t tell in these shots however I am about two fingers from the non rolled lip in front, looks like this:
I am running 225/50-16 on Eibach Sportline springs with -1.5 camber all the way around. +40 offset
seems like that size should be ok for me. thanks for all the input guys :up:
