I’ve got a chance to pick up a 4 dr parts car for $200, which would be perfect to get my DA back on the road. I’m just wondering about a couple of things though…
Does anyone know if any of the following will work on the DA
- speedo cable (i can’t see why it wouldn’t, front ends are the same)
- fuel door cable
- Hatch/trunk release cable
- Rear speaker covers/enclosures (I’m thinking not)
The rest of what I need, I know will work (hood, fenders, windshield)
Yes- speedo cable (i can’t see why it wouldn’t, front ends are the same)
I would think- fuel door cable
I would think- Hatch/trunk release cable
Nope- Rear speaker covers/enclosures (I’m thinking not)
http://www.acuraoemparts.com/delray/jsp/catdisplay.jsp?inputstate=1&catcgry1=TL
Use the parts select in the little yellow bar and go from there. you get to see the exploded view. Compare both versions and see if part numbering is the same.
And, when you’ve discovered what will or won’t you need to tell us so we can search and “FIND” an answer.
everything but the speaker covers will work. with the trunk release cable i’m pretty sure it’ll work. u just have to fasten the extra slack down… so that when the lever is pulled… only the inner part of the cable is tugged on, not the entire thing. (like a bicycle brakes). zip ties can be handy for that.
I was just too lazy to check it earlier, i hate looking through those pictures.
Some of the stuff is never where it should be
2 Door
74830-SK7-A01 CABLE, TAILGATE OPENER (LH)
74411-SK7-A02 CABLE, FUEL LID OPENER
78410-SK7-A01 CABLE ASSY., SPEEDOMETER
4 Door
74880-SK8-A01 CABLE, TRUNK OPENER (LH)
I couldn’t find the fuel cable for a 4dr. I must be blind. It’s in the same picture as the trunk cable, but there’s no part # for it
Negative on the windshield.
90 gs 2dr = 73111-SK7-0000
90 gs 4dr = 73111-SK8-0000
The angle of the windshield and a pillars are different from the 2dr to 4dr. The 4dr is actually angled back further.
Which also makes the mirrors (at least where they attach) different.
Shit that’s good to know. thanks man
