This write would be on how to install the 4 door handle’s on to a 2 door.
** This would be my first write up **
First you want to start off by taking of the door panel.
There’s a screw you need to remove from the handle you use to close the door shut with.
There’s a plastic screw you need to remove from the panel on the top corner below the inner mirror cover.
There’s a clip you need to remove from the window cank handle. I suggest using a flat head.
This is the clip I’m talking about.
Just go ahead pull the window crank handle towards you.
Go ahead and pop out the door handle you use to shut the door with.
Remove the speaker grill(s) There’s a grove on the bottom you could pull/pop them out with. Once you remove the speaker grill’s, you could go ahead and pull the door panel off. Best way is to start from the bottom and pull towards you.
This is the door handle’s compare next to each other. The top is the 2 door handle and the bottom is 4 doorhandle.
You need to drill out this rivet.
Side view of the 4 door handle.
Rivet almost drilled out.
Once you drill out the rivet go ahead and remove the bracket and spring from the 4 door handle.
Now you want to drill our a hole big enough to fit the door handle link. BE VERY CAREFUL NOT TO DRILL A HOLE TO BIG CAUSE THIS WILL WEAKEN THE HANDLE AND WILL BRAKE. SOME HAVE USE SOME TYPE OF J.B. WELD OR SO TO MAKE IT STRONGER.
The 2 door handle you will be removing from the door.
