3 amp and eq setup question
here is what i have!
JVC cd headunit
speakers…2 10’s in a box, sony speakers front and back
Sony Mk11 eq
1000watt 4ch amp for the subs
200 watt amp for the rear
200 watt amp for the front
I basicly have all the wires ready to go i just need to find a diagram of how all the av jacks are connected
with the eq,headunit and to each other…any diagram would help
thanks
We need more specifics on your amplifiers and subs before we can help properly.
Do you want this set up for spl pounding power or clean and accurate sq? or both?
Are we to believe that the 1000W amp you have will produce that kind of power? Let’s start with the fuse size in the back of the amp – what size is this?
Thanks.
Andrew.
I just got finished hooking everything up! but the problem that i am having is the memory,amp remote,headunit remote and the eq remote wires.
from my other post i found out that the WHITE/blue wire is the memory but the headunit still isn’t keeping the channels memorized.
By the sounds of it, you may have the constant 12V and the 12V switched wires mixed up. In other words, when you turn the key off, the memory in the deck gets wiped. Try connecting the wire that you have connected to the switched ignition lead to a constant 12V source…
email me privately if you need some direction on this.
neex@redbull.nu
Andrew
aka neex.
