3 Post Mount in DA/DB
Si I was just thinking will a 3 post mount setup out of a DC/EG swap work in a DA chasis. I’ve seen it before somewhere but I thought I would just check to be 110% sure I wasn’t imagining it.
What you mean? Using three mounts, instead of 4?
No what I mean is the timing belt mount on our cars uses only 2 posts to hold the rubber mount to the metal bracket on the block where as the newer integras/civics sometimes use a 3 bolt mount
