Dumb question, but like it says, will a 3rd gen GSR throttle body work on a b18a/b? I’m having an idle issue with my setup - can’t seem to get the idle to drop below 1200 rpms. I have a b20 throttle body installed on a Blox intake manifold. For those who are familiar with the Blox/S2 intake manifolds, the FITV mounting spot is missing, so I need a throttle body that has the FITV mounted to the bottom. I have some vacuum leaks around the TB and I think it’s due to the fact that the B20 TB either doesn’t work with this setup or its cracked. I have a chance to get my hands on a 3rd gen GSR TB and from the looks of it, it should work, but would like to know if anyone else thinks otherwise.
Any thoughts?
[QUOTE=frozenrice;1731682]Dumb question, but like it says, will a 3rd gen GSR throttle body work on a b18a/b? I’m having an idle issue with my setup - can’t seem to get the idle to drop below 1200 rpms. I have a b20 throttle body installed on a Blox intake manifold. For those who are familiar with the Blox/S2 intake manifolds, the FITV mounting spot is missing, so I need a throttle body that has the FITV mounted to the bottom. I have some vacuum leaks around the TB and I think it’s due to the fact that the B20 TB either doesn’t work with this setup or its cracked. I have a chance to get my hands on a 3rd gen GSR TB and from the looks of it, it should work, but would like to know if anyone else thinks otherwise.
Any thoughts?[/QUOTE]
through the fast idle away thats junk. yes u can use a 3 gen gsr throttle body. but u need to ext the wires so u can use the map sensor on the throttle body. u will no longer use yours.
haha. If I lived in a warmer climate like you, I’d junk the FITV for sure, but I need to have it. It gets cold up here. Thanks.
The 3rd gen throttle body opens up backwards…meaning you would need to order a throttle cable from Acura…I had to do it with my b18c1 headswap
