4 door rear door handles
hey does anyone know how to install these things? im having a hard time…
http://www.g2ic.com/tegtips/exterior/12.html
oh shoots thanks!!!
im stuck at taking out the plastic clip… any technique used here? the metal thing is in the way how do i take that out?
A needle nose & regular pliers to “squeeze” the plastic grommet, and a flat head screw driver to push it out simultaneously. It would be easier if you had a friend to help ya. Taking it out was easy, putting it back was a b!tch.
ok thanks for your help…
i kinda already figured i could do this but…
is it ok to just cut off the part that needs to be bent with my dremel?
just for others to know
