5-speed
Ok, I’m doing it. I am going tou and buying a 5-speed. But I want to make this the last Tranny I need to buy. I have a 91 GS 4dr. What is going to be the best buy $ is not really the issue(not totaly) I am going to get a Drag Turbo kit over the summer to make the car more fun and help Pop the motor faster. Do you that KNOW think I should get a GSR or stick with a LS?? And what year does it have to come out of for either one. Would it matter that I had a GSR tranny with my Non-Vtec B18??
you need to research your turbo setup more. Find out what type of turbo you’re going to run, how built the motor will be, how much boost you plan on running…etc…etc… then once you’ve got all that figured out you can ask the turbo guys what type of tranny to run (vtec or non vtec). Typically if you run turbo you want to run a non vtec tranny…but i’m sure there are exceptions to this rule. You really need to go the Forced Induction forum and talk to those guys, you won’t find much help in this forum considering its an NA one.
The year of tranny does not matter. As long as its a cable tranny. And you’ll buy the clutch for the tranny…not for your motor.
