7.5 sa meter fuse keeps blowing!!
This is driving me crazy!! The 7.5 meter fuse pops every time I put my car in reverse!! Can anyone help me out here? I’ve tried to search and came up with nothing!! Please!! This is also a 5 speed car.
If it only happens when putting car in reverse, check to see if you have back-up lights. if not check the wiring for the back-up lights, back-up light switch in transmission, the back-up light housings, [bulb holders]
Question, MM&Y of car?94
[QUOTE=fcm;2246885]If it only happens when putting car in reverse, check to see if you have back-up lights. if not check the wiring for the back-up lights, back-up light switch in transmission, the back-up light housings, [bulb holders]
Question, MM&Y of car?94[/QUOTE]
Thanks for the reply, but I figured it out…it was the green wire that goes to the transmission, it was the touchin the tranny…I heat shrinked the connectors n it stopped. Thanks tho
Do you mean the green/black, output from back-up lights switch to the back-up lights? 94
Which fuse works the reverse lights? I can not for the life of me figure out why mine do not work. I gotta trace the entire wire now. i tried jumping the switch and it still didnt turn them on…volt meter shows 12v at the connectors with key on. Bulbs are good.
[QUOTE=da6YO;2249174]Which fuse works the reverse lights? I can not for the life of me figure out why mine do not work. I gotta trace the entire wire now. i tried jumping the switch and it still didnt turn them on…volt meter shows 12v at the connectors with key on. Bulbs are good.[/QUOTE]You have a connection problem, check the connection of the rear harness, at/around under dash fuse box. 94
