my car is redlineing at 7000 instead of 7200. also the gas mileage is sucking. IV heard of this problem before but cant remember what it was???:eek:
what engine and ecu do you have?
also, there is a difference between redline and rev limiter. You’re talking about a rev limiter.
its a b18 with stock 93 ecu ya i meant rev limiter… it just changed all of a sudden … there is something that breaks that messes it up like this but i cant remember and cant figure it out i waas thinking like O2 sensor but wouldnt that make check eng. light go on?..
i thought that the rev limiter was at 7000. Redline is at 6500-6600 and then the rev limiter kicks in at 7000. I’m not positive on this cause i’ve only hit mine a couple times and both times by accident.
on 92-93 its 7200…but the worst problem is the gas is going alot faster then it used too
