Hi guys,
I am new here with my recent purchased 1990 DB1.
The passenger side fender on my car is busted and I am trying to look for a quick replacement locally.
May I know if the factory white color on 90-91 is the same as the white on 92-93?
if there is? how much of a color difference?
thank you for the help guys! appreciated it:rockon:
-Jac
As far as I know there is Frost White and Polar White. Polar White was 90-91, and I believe Frost White was introduced in 91.
so my 90 is a polar white from your info.
but then, is all 91+ white frost white? or were they both available during the run of production?
do you guys know how different of a white shady they are?
Your color code for your car should be on the driverside door, on a sticker.
Hopefully this shows up. I have a 90 in Polar White. The spare door I have on is from a 92 so therefore Frost White. In certain light it is very obvious. The Frost seems to have a bit of a blue hue to it whereas the Polar is more yellowish…
thank you so so much for the pictures
I see the difference from the photos and
it becomes very clear now!
although they are different but close enough for me as of now. (my car isnt perfect, and having a good shape fender is better than a busted one anyhow)
Thanks guys!
:rockon:
