are those leads linked to any fuses in the kick panel? if so whatich ones?
this is a great teg tip, i have wired my fan and fuel pump up via these things .
i used this to fix my radio. it was all screwed up but basically, it got spliced into the acc wire next to the ignition adn thats how my radio was getting power.
the only downside, when i turn on the front wipers the radio turns off and i could have it up to loud or else it would flicker with the bass and turn off…
but i got one of those fuse-in-a-wire things and hooked it up to number 3 and problem solved…
there is a fuse that would blow using terminal 3 its the radio one. i wired my fan this way for a short time and it blew once did the trick before i fixed it the right way
Top shape,high-end design and style trends,pop elements do in our online store. All discount handbags,and ysl shoes are the year’s most fashionable trends boutique.Christian Louboutin Shoes designed by christian louboutin,and christian louboutin will help your show your charming temperament,there are Chanel Shoes and designer handbags,so you have to shape the individual in cold weather unique charm, of course,there are handbags in Manolo Blahnik Shoes,to ensure affordable,as well as ugg boots in UGG Classic Cardy Boots,and ugg classic short Ultra-wide size,ultra-low prices.Your support,will be our motivation.
