90-93 rear subframe reinforcement ?
are you talking about like an x- bar type thing? if so, try explicitspeedperformance.net and search for JDM DA6 Honda Integra Miracle X Cross Bar NeXT XSi on ebay.:slight_smile:
try http://www.g2ic.com/forums/showthread.php?t=160519 or diy rear tie bar. i ended up having to do it this way and it turned out real nice:)
If you are trying to get this to run a stiffer rear sway bar, I say make your own. I stalled a 23mm JDM ITR rear sway bar and reinforced my rear subframe out of billet aluminium sheets.
ASR as far as i know does have a subframe kit for our cars, or atleast at one time did. i dont know if they do anymore though.
i beleive it is not a sub frame kit, it’s a sway bar kit for a 32 mm sway.
i saw a kit just like the one pictured above for our cars it was like 450 but i dont remember where it was.
nevermind i think that was just a tie bar and sway bar combo kit. sorry for misleading anyone if i did.
I’m pretty sure the 32mm rear sway bar come’s with the sub-frame reinforcement plate. There website has a picture of all the stuff together.
ImportAutoPerformance.com said that they have the DA ASR kits, but I am not sure what the prices are.
Here is a link to a post with pics of the kit installed.
http://www.honda-tech.com/zerothread?id=1616906
DigitalHorizon: want to make me one? :stare:
I didn’t make it, I’m just the tag along.
That’s Pat’s setup? Daniel, do you have any more photos of how he actually connected the bar? Its an ITR bar, right? Doesn’t look like the standard way to install those on our cars, usually people put D brackets by where the lca bolts to the subframe…
also interseted in more pics digital.
