90 da obd0 to obd1 conversion help asap
I have a 1990 integra and b20b long block with b18b accessories as in intake manifold injectors throttle body distributor obd1 ecu and alternator i also have wire harness off a 1994 integra incase i have to switch any connections and i just ordered a obd0 to obd1 jumper harness for ecu and distributor…im using my ls cable tranny and i dont have any parts from the original b18a1 engine
so question #1 is do i need anything else for this swap?
#2 what conections do i need to switch from the odb1 harness on to my original obd0 harness??
#3 what do i do about the 4 wire o2 sensor???
Search! However, this link is a great starting point and should answer most of your questions, written up by @Colin so he gets all the credit: http://forums.g2ic.com/forum/information/articles-teg-tips/38286-obd0-to-obd1-conversion-basics-obd-0-obd-1
Your post has been so helpful because it was clear and concise writing made it easy to understand. Thank you!
192.168.1.1
