90 DA. wiring hellscape. cut wires everyewhere. pics and good descrip inside.
ok so i just picked up this 90 to transfer all of my interior and random parts into.
it had one pieces and i couldnt even begin to understand what was going on.
so i cut everything back to stock wires. now i have headlights, bumper blinker, and constant sidemarker. no voltage on the blinker wires that are next to the headlight.(grn/wht and grn/red wires)
ok next onto the interior, the “clock,cig lighter,interior light” fuse (#14/15a), keep blowing. i know its a constant 12v so it blows without the acc ign being on. i unplugged the clock, lighter element, and all the connectors on the fuse panel itself. and it still blows the fuse. so from what i have searched this means the icu needs the capacitors replaced. correct?
the hazards work, both front and back. but that is controled by the hazard blinker relay, which is also the same circut that the BUMPER blinkers are on correct? this is why the bumpers blink and work correctly, but the light that is suppsed to blink next to the headlight does nothing. this is because those lights are run off fuse # 14…which is the same line that is feeding the dome,cig lighter, so this is surely the icu acting up, correct?
also this is the plug that is connected together near the back of the fuse panel. its the rear harness, looks like this wire was either pulled apart or cut. but i cant find the other side of the wire. and nothing else is cut/ missing. its white with green stripe.
any ideas? i cant seem to trace it in the wiring schematic.
this wire was cut on the passenger side. easily traced to under the hood,
reconnected and now all the seatbelts and warning chimes work. except the “lights left on” chime.
now onto the doors. looked to me like it was hacked up to put in an alarm with window down remote controls. cut all the aftermarket out, and re-connected it all to factory spec.
no window control still. ive checked the fuse panel for the two window fuses. (#7 and #2)
both fuses good, and there is 12v and both the fuses. checked the door ground and it is good. no power to the door switch at all. checked the wht/yel wire and the blu/blk wire nothing. at all. perhaps the window relay? how should i check to see if the relay is the problem?
any help would be great! cough**fcm!!!**cough im going to move on to other things for the time being, built a harness to do the bumper light trick, but not going to install till all these issues are fixed!
thanks everyone!
