90 GS 1/4 Times
Well, after seeing everyone post there times, I decided to give mine a shot and get some feedback.
Car is a 90 GS.
Mods are as follow:
-JDM B20B
-No A/C
-ACT Heavy Duty Clutch w/PP
-Skunk 2 Intake Manifold
-AEM Short Ram Intake
-JDM B16 Tranny
-Omni Power Coil-overs
Here is my lowest MPH:
R/T - .552
60’ - 2.308
330 - 6.516
1/8 - 10.009
mph - 70.74
1000 - 13.119
1/4 - 15.773
MPH - 82.68
My fastest time:
r/t - .554
60’ - 2.290
330- 6.497
1/8 - 10.010
MPH - 70.27
1000 - 13.053
1/4 - 15.610
mph - 87.33
I was still spinning thru 1st and while shifting from 1-2 and 2-3. I’ve checked and people with my set up ran faster times. Any ideas would help.
lower your 60’ times to 2 seconds or lower and youll be in the 14’s, thats about all you can improve on for now
little better reaction time and little better 60’ and you’ll be laughin
A sub 2 second 60’ time on street tires? I’d love to see that.
Wow, with those mods done to the b20b, especially a b16 tranny, something isnt right. Your mph is very low first off, and 60ft times are not that bad, 2.2 is descent for street tires. What are you weighing in at? Im going to suggest that you change out that rescrictive ass exhaust manifold, if you havent already, its choking your b20. Try gutting that DA and practice launching and seeing where you hook up.
I also have a b20b with many bolt-ons and being gutted on falken ziexs (shit for grip) and pulled a 14.6 @ 95mph, thats with 95 ls cams and still sporting the LS tranny. I should be low 14’s now if i can ever get a 2.1 or 2.0 60ft. But for that to happen im going to have to pick up some BFG drag radials. Its the only way.
I’m at stock weight. I’m planning on gutting the interior next time to see if that will lower my times. I already have a JDM 4-1 header thats waiting for install along with a test pipe.
I’m also on the same tires as you are and have trouble gripping. What are you 60’ times on those tires?
what’s your stamp code on the B20B?
B20b / P75-5
:up:
tire psi?
what size wheels/what tires are you running?
205/50/15 Falken Ziex
28 PSI
My best 60ft. was a 2.2. Try to get that 4-1 header asap.
Putting it on soon.
