Introduction: 1990 LS, Polar White, Blue Interior, 68K, all stock, new to this forum. By coincidence, started work on this car about the same time as Dmorga1 on his, or within the same week (chuckle).
This car has had a bit of a sad history, first used as a daily driver for five years, then as second car and well cared for, then stored for a few years and kept essentially mint, except for one minor dent which was professionally repaired. Then vandalized (broken rear glass etc), and repaired again. Five years ago, while loaned out, in an unfortunate chain collision and later while parked awaiting repairs, hit from the side by a moving truck (yes, really). After that, it pretty much sat outside.
When I took the front apart in August, most of the damage turned out to be fairly superficial, and with a new battery the engine actually started and ran pretty smoothly. Engine seems to run fine, seats, carpet, and all interior still look mint. So, decided to make it drivable again mostly as a personal challenge, and I felt bad to let it go for just parts w/only 68K miles on the odo. Also felt encouraged to see what other people have done with these cars!
Replaced so far:
RF headlight assembly & corner light (crushed)
Front bumper, fender, hood, air box (broken/dented)
One caliper (rusted solid), all pads & rotors (rusted/pitted)
In progress:
LR quarter panel repair/refinish/paint
New exhaust, in shipment
Front struts and springs, on hand
New/used hood needs removed and aligned
Lots more to do, interior aft of the front seats has been removed to repair the rear quarter properly, rust found in the trunk, antenna rotted away from the inside, one tail light fills w. water when it rains, gear shift lever moves like molasses, every single bracket that holds anything in the engine compartment seems to have some rust, some of the suspension bushes look a bit dodgy even though the car rides fine.
Everything done so far (bodywork, brakes, suspension, exhaust…) is pretty routine, and would be the same on any car. I am sure will be scouring the threads when I get to the more interesting bits.
Suggestions, comments, snide remarks all welcome… ![]()
(car is on stands in this picture, so distance from ground appears a bit odd)
