90 teg dieing/bogging/idleing rough
igot a 9 teg its been sitting all winter and id start it everyweek but its been idleing rough it goes very low rpms and feels like its guna die…yesturday i drove the car to work on my way back i put it in first gear and started to go and the car bogged then kicked in and it was fine… when i got home i turned off the car then turned it back on wouldnt start. after tryin couple times it startd then turned it off and it would start up but then die right away and at times it doesnt start…i just changed the ignitor in the distributor last summer because it went on me…im not sure if its the ignitor again or fuel problem… if any1 could help that would be awsome (im dieing to take the car out again)
change the plugs wires cap and rotor oh and airfilter along with other PM’s
everything has been changed already
check the fuel pressure. the pressure for the 1990 integras should be 26 to 32 psi with hose attached. with the hose unattached should be 35 to 41 psi.
now you said the car sat all winter only idling every week. possable got a tank of bad gas. check your pressure and let me know and i’ll walk you threw.
i have a fuel pressure regulator its at about 39psi and i filled up my tank of gas i had used all the old gas that was in the car…but now for some reason the car is starting fine but im afraid if it just dies on me on the road or something… its weird
Just want a update if you fixed it and how cause my car does the same thing.
