90 teg P/W,P/L conversion?
hey guys, i would like to convert my car to PW/PL.
what parts do i need?
i have been searching but no luck.
tnx
what trim level do you have? (rs, ls, or gs?) I have to assume that you have a rs, since they came with niethe options
I will be converting my 91 ls with pwr windows and manal locks to power locks. As long as you are going to do both, you will need to get equipment off a 91-93 gs. I would suggest getting all the equipment in the doors (door harness, door lock actuators, and everything) and the door panels. You may just might as well get the full door and just disconnect the door harness from the body which will be a task but it may be easier than taking all the components out of the door and then putting them back in your existing doors.
I wish I had better news or a easier way of doing it. Maybe someone else will have another idea
its a LS tho, i have power mirrors and thats it.
my friend has the doors but not the door panel.
if i cant find a door panel, i guess i’ll just have to wire it up my self.
make my own switch ect.
hahhhaa idk yet.
lmk when you do yours.tnx
I have an LS with power windows but no power locks. I added power locks with a universal kit from eBay. It came with wiring and two actuators. I just installed them under the door panels and ran the wiring through the factory rubber tube from the door to the body of the car. There are no switches, if you unlock one door the other one does too. I also added an alarm and so I can unlock/lock them remotely now.
yea i heard about those kits.
tnx
btw does any one know if i need a floor harness for this convertion?
part list.
window regulators
cabin harness
door harnesses
door panels
lock actuators
lock switches.
door lock module for a 4dr
maybe a fuse
ive done this on a 2dr but i know its basically the same as a 4dr. getting the blue harness connector through the door jamb is probably the worst part because of the dash. good luck
