9004 to 9007 conversion
hey for the 9004 to 9007 conversion if i did hids with that make a differenc e otr not cuz the y all say 8000k
Uh…8000k refers to color of light.
in regards to the OP, no. Any and all plug and play kits use the same bulb design, which is D2S. The only thing different are the bases and the colors. as spikey said 8000k is the color.
if you plan on going HID 8k is quite blue. 6k is really white and somewhat blue. But you can already tell its whiter/bluer than factory HID systems which kinda sucks.
I would personally go with a 4300k bulb. its going to give you the best light output.
Yup anything over that you might as well just stick with those xenon halogens on ebay… they give the same light output, which is crap. If you want better light output on your stockies, just do the 904-9007 conversion and get the Sylvania silverstar ultras :whisper:
If he wants better light output, then get a bulb with no coating on it.
Any bulb with a coating on it reduces light output. Even Silverstars.
