So I ended up getting some mint ass 1pcs from this dude in CT and had a tough time getting a h4h Hid kit. So I realized that my boy had a set of 9007 hid kit that he had in his Explorer. So I ended up shaving them and making them fit my 1pcs.
Here what you need:
-Jdm 1pcs
-9007 Hid Kit
-Dremel
-And Pliers (Optional)
*Will advice to remove your headlight will save some headaches.
*Prolly be better if you see the pics then youll get what I mean.
First you get the bulb and start shaving the edges of where the bulb is sitted onto the socket with the Dremel. Be sure you have a good grip on the bulb dont want it to slip and hit the ground or have the Dremel slip and hit the bulb. Also see pic of bulb if you shave it wrong the bulb wont sit right.
Second after you have the bulb in you have to bend the metal “spring” that hold the bulb in place so that it is held in there right with the pliers. It is probably going to be a bit tough to get it right but youll get it. You could use pliers but I just used my hands.
And lastly put your headlights back in and install your hid ballast and plug everything back together.
Couldnt post pics sorry but Email me and Ill send pics
Bulbs sit perfect neither is higher than the other have no problems or regrets. If interested in more details or need to explain more let me know b.saravia1@yahoo.com
