91 DA Yellow/red wire madness!! Dome light, radio, clock fuse blows instantly
How is it going everyone! Ok I have had my integra for about 7 months now and when i got it the dome lights and clock didn’t work, the cd player was working but had no memory cause it both power wires were only on 12v switch and not constant 12v/switch. I tried changing the fuse but It pops instanly so I thought maybe a broken bulb or something I changed every single bulb in the car with brand new bulbs, Headlights new, brake bulbs new, dome lights new, cluster bulbs new, climate control bulbs new, all blinker bulbs. Didn’t change anything! I took apart the fuse box inside of the car and found a melted yellow/red wire (the constant 12v power wire), I’m trying to avoid taking the dash board out and removing the chassis harness to source the problem as the car is my daily driver and I just don’t have time for work like that right now.
Is there anything else it could be? I’ve checked all connections to all the lights on the car, dome light, cluster, blinkers, headlights, tail lights, rear hatch light, fog lights.
One more thing the Clock will work if I push in the plactic cover for the buttons
[QUOTE=b20 ant;2302993]How is it going everyone! Ok I have had my integra for about 7 months now and when i got it the dome lights and clock didn’t work, the cd player was working but had no memory cause it both power wires were only on 12v switch and not constant 12v/switch. I tried changing the fuse but It pops instanly so I thought maybe a broken bulb or something I changed every single bulb in the car with brand new bulbs, Headlights new, brake bulbs new, dome lights new, cluster bulbs new, climate control bulbs new, all blinker bulbs. Didn’t change anything! I took apart the fuse box inside of the car and found a melted yellow/red wire (the constant 12v power wire), I’m trying to avoid taking the dash board out and removing the chassis harness to source the problem as the car is my daily driver and I just don’t have time for work like that right now.
One more thing the Clock will work if I push in the plactic cover for the buttons[/QUOTE]
Did u fix the problem? My teg does the same thing too
No I didn’t fix it and I was about to take apart the dash but I said forget it and i’m making all new wires for interior lights and cig lighter. I’ll take some pictures and make a video so you can do the same to your car! I took apart the fuse box to make sure it wasn’t in there and it’s not so something happen in the chassis harness. I’m going to eliminate the wires on that fuse all together and make my own mini harness
I bypassed that White/blue wire from behind the interior fuse box and just make my own power wire for Cig lighter, interior lights, cd player. P.m me for detail it’s very easy I’m not to familiar with electrician work and I did it very simply with a little help from my friend over the phone but that was just questions about making sure I don’t over power anything and If I’m using the right size gauge wire.
