Hello. I have a 91 GS with a lot of work done. Basically this car sat for about 5 years in a barn and I thought it would be great to bring it back to life. The car started as an automatic, but I have swapped it over to manual (used) transmission, while I also rebuilt the engine (seals, bearings, rings, valves, etc). I am still using the automatic ECU, as I have found no real reason not to locate another one, other than a CEL for a removed EGR system (using a block off plate on the manifold).
I’ve had some idle issues for a while that I have almost completely solved. Basically the former owner messed with the throttle stop to fix other issues, and i’ve had some difficulty getting that and the TPS back where it should be.
On to the problem now:
Since I have slowly fixed some of the other issues, the most glaring problem is a problem that occurs under mild acceleration, between 1,500 and 2,000 rpms, regardless of gear, although it is more apparent with lower gears.
Best I can describe the feeling is a “bounce” or stumbling acceleration. If am going up a small incline and I try to hold steady in 2nd and about 1,600 RPMs, i can really feel the issue. Maybe 4 “bounces” a second? I can push through the and once I get past about 2,000-2,200 rpms, I don’t notice it anymore.
I honestly can’t tell if this is a misfire or something else.
I’ve replaced the spark plugs (2nd set after rebuilding the engine), checked for vacuum leaks, swapped TPS, checked the valve timing and ignition timing (many times), checked the fuel pressure, I have a new IACV… and more. Nothing seems to have affected this issue. Issue occurs regardless of engine operating temp, although it does seem less noticeable after driving at 60+ mph for a few minutes.
There is one other issue that may or may not be related, and that is at idle, the idle speed will fluctuate slightly, but it seems more like something is cutting off the fuel or air completely for one or more cylinders, which causes a momentary drop of about ~100 rpms (according to the tachometer). I really only notice this at normal operating temp. I have the FITV closed up as far as it will allow, but seems
I can post a video if anyone thinks it might help.
Edit: I have hooked up a vacuum gauge at idle, and it shows a rapid “flick” or bounce between 20 and 21 in.Hg. Normal decrease and increase on throttle change.
