91 integra Fuel Sending unit
Hi Guys,
Need alittle help here. I had to drop my gas tank to replace my fuel pump. My question is for ppl that had to drop their fuel talk to replace the fuel pump, did you had to drop the fuel tank AGAIN to replace the level sending unit? I remember seeing it, but I dont remember if i could pull it out just from taking off the backseat.
The sending unit you can access under the rear seat. Remove bottom of rear seat and you will see the access plate for it. No need to drop the tank.
