so everytime i peel out i see two skidmarks from both of my tires. does that mean i got lsd?:excite:
Someone probably slipped it into your drink. Just find a place to lay low for a few hours and you’ll come down eventually.
my 90 gs A1 tranny does the same thing everytime in first but 2nd goes to one…and sometimes if i am turning and the angle is right it bumps like it has a limited diff
no, some tegs do but its cuz we have halfshafts, im not sure about the specifics or how it works but our wheels do spin at the same time but no lsd. i saw something posted about this acouple months ago, exact same quistion
pull ur passenger side axle to know for sure… also a good time to do a transmission flush… =)
This^^ a true lsd don’t have the bar running threw the def. If you can see right threw the other side without a bar in the way,its LSD. You can also turn the tires all the way and try to burn out,if one spins,its not LSD,one both tires should give way but one more then the other.
Here is a grate article about how LSD works and the different makes that are out there.
http://www.team-integra.net/forum/display_topic_threads.asp?ForumID=10&TopicID=289006&PagePosition=1
