I am thinking about selling my 91 integra, lots of after market parts.
race prepped b18a1 bottom end, ported and polished head with dual valve springs and titanium retainers, web stage 2 cams. Stage 2 clutch, stock trans, oil cooler lines, setrab oil cooler, remote oil filter by power steering pump, Aem adjustable fuel pressure regulator, 10 percent better flowing injectors, fuel test port, fuel pressure gauge, gates racing radiator lines, aluminum full core radiator. Suspension mods, advance design nitrogen shocks, 750 rear springs and 600 front by eibach, nodded front subframe with spherical bushings for radius arm, new inner and outer to erode, new upper control arms with new ball joints, new lower control arms, rear upper adjustable control arms, new lower with aftermarket bushings, poly bushings in everything, prothane rear trailing arm bushings, arp extended lugs on all 4 corners. Lots more I’m prolly forgetting like quick release momo wheel, gauges, hasport shift linkages, aluminum shift bushings, skunk 2 shifter, tuned ecu, and more. Car has more in mods than body looks to be worth lol.
