91 Teg lighting question.
Hey there I have a 1991 Integra GS , 3pc headlights , I notice that my parking lights don’t turn on (gotta check bulb and fuse, my fog lights come one with my headlights, but turn off when I put on my high beams, or turn my headlights off, my bumper lights work fine.
Without modification are my fogs supposed to turn on without my headlights. Even with the switch on they don’t. My buddy also told me that I can take some wiring from DC tegs so that my fog lights stay on, and so my bumper lights stay on too and still blink with my corner lights?? Thanks
Fogs only come on when you turn your headlights on and turn off when you turn on your high beams. So your fogs are fine. Not sure about the rest.
Alright thank you!
You can modify the switch on your fogs so they can turn on and off without the headlights on. You don’t need dc wiring. Just remove the fog switch, locate the power wire( it only has power when low beams are on if you’re using a multimeter), cut it and supply a 12v supply wire from either the fuse box or another switch nearby to the wire going to your fog switch. This mod is also posted in the TegTips. About the bumper lights I don’t know.
Thanks for the response , my switch itself is missing the actual fog light symbol and I have a new one to replace it , so I might just do that while I have it out
Why do you even want your fogs on without the headlights?
I want my fog lights to run along with my parking lights , like my 99 civic does. It’s just personal preference I like the looks of it.
