91vs93 prothane mount differences
Im looking at the prothane motor mount inserts on ebay. The obd2 mounts are about 10bux more than the obd0. Can any one tell my why ?
Im buying a lsd cable trans with shiftlinkage next check, can i reuse the 91
ys1 clutch and flywheel ? any tips?
the mounts on the passenger side are different between the 90-91 and the 92-up
is it different enough not to be able to use the lsd cable tranny ?
if you have a 91 your tranny wont be a ys1 unless your talking about the new tranny. if your putting in a ys1 and you already had one then your fine but if you have a 90 91 tranny(s1 a1 or any jdm tranny) then your gonna need a new clutch for the ys1. hope this helps.
the tranny in it has a sticker with a barcode the first three characters are ys1. I bought the car used so i dont think its the stock trans. So what spline would I need ? later
your gona need a clutch for a 92 93 tranny im not sure as for the spline count though.
