I was wondering why everyone always assumes the 94-00 gsr is a faster car than the 92-93 gsr? I have a 92 gsr with some modifications and my buddy has a newer model with the same modifications… both manual , and we are about equal drivers and I always pull away from him, Is it because of my shorter gears ? I would almost have to say the older gsr is faster, opinions!
lighter weight man. put a b18c1 in your gsr and you’ll walk away
I walk on g2 gsr’s in my G3! I only have I/H
edit: I walk on g3’s with I/H/E also!
edit x2: and its a 4 DOOR (3680lbs.)
Don’t forget about wear and tear. A 13 old motor won’t do as well as a younger one. They are pretty equal, really comes down to the driver.
ripped a g3 gsr also w/my g2 gsr…it all depends on driver( IMO )
I walked a 96 gs-r with a b16 and IHE on my 93 LS EASY
10 hp difference from the word go and less torque too. Other than that, all driver. Assuming stock vs stock anyway.
There is no way a 4 door G3 weighs 3680lbs. I have a 95 Accord sedan that I dont even think weighs 3000lbs and there is no way a G3 Integra sedan weighs more.
Nope that way to much unless he has a huge stereo. My sedan weighs 2989 with me in it and Im 220. That includes a full tank of gas and a small sub box with 8’s in it.
Who says G3 GSR’s are faster than G2 GSR’s? i always heard it was the other way around. G3 GSR’s engine is more powerful, but G2’s make up in less weight and there shorter gear ratios i believe
I stomped an RX8 twice 1/4 mile with two different drivers behind the wheel.
Me: 1992 GSR
Try that in a 94-00GSR with I/H. Good luck.
1992-1993 GSR all the way.
The sticker on my door says “GVWR 3680LBS GAWR F 1985LBS R 1740LBS”
Which means it weighs 3680!
Front weight 1985!
Rear weight 1740!
I took a picture of the sticker but cant find the cord to hook up my camera!
My modifications are: ebay SRI, ebay 4-2-1 headers, stage 1 exedy street clutch. The thing is that I can drive better than most peeople (i know everybody thinks they drive better than everyone else) but, I beat cars that I should NOT, and I run the 1/4 mile 1 full second faster than my bro in my car. Ran a 15.2 right before my presure plate broke.
Yes, I have beaten
4 - G3 2dr GSRs
3 - G2 GSR’s
2 - G3 4dr GSR’s
3 - RSX type s
1 - Jetta TDI
2 - jetta 1.8T
1 - Jetta VR6 (sat side by side whole time)
Lost:
1 - Jetta TDI (modded with i/h/e/chip)
1 - G3 GSR (forgot to turn a/c off, only lost by like 1/2 car)
the g2 gsr’s seemed bone stock
the g3’s gsr’s had slightly more bolts on than i did!
GVWR=
Gross
Vehicle
Weight
Rating
or the MAX that the suspension is designed to hold.
Front weight 1985!
Rear weight 1740!
Yeah, but GVWR is totally different than the actual weight of the car. Go put your car on a scale somewhere and I guarantee you it wont be even close to 3,000lbs.
ok, i guess im wrong, but thats what everbody kept telling me to look at for wieght, oh well!
See if that sticker has a max cargo weight anywhere (sometimes they do). Subtract that from the GVWR and you get a pretty close empty weight of the car.
Oh ya, that sticker is usually the weight of the car with four passengers. Cant really go by that number. Truck stops will sometimes weight your car for ya. We have a animal supply store across the street here that has a scale they use for like landscape crap that they sell by the pound that will weight the car for 5 bucks. Mabie find something like that…that is if you really care.
if you really want to know just look at your vehicle title if you have it. it will tell you everything. i work at a dealship…
i walked g2’s,g3’s,eclipses turbo,1.8t volks,rsx type s,acura rl a-specs with my 95 4-dr w/97 jdm itr swap i/h/e all day…the car is banana’s…when i had my 92 gs-r back in 2000,i used to shitted on a 4.6 mustang v8 5-spd 3 times in a row…all i had was i/h/e…but hands down 94-00 gs-r will most likely take a 92-93 gs-r that i experinced!!
I,ve got a 91 LS with XSi B16A in it and i/h/e and took 2 G3 GSR’s at the LVMSW. Z28’s, 4.6 GT Mustangs, and an all motor eclipse(G2 also). G2 GSR over G3. . . Why not!! If I can(specs don’t add up), then G2 GSR can any day!!
