Will a 92-93 Integra GSR OEM muffler fit good on a 88 civic sedan ?
heres some pics to show…
I’m pretty sure no one can answer that unless they have personally done it. Also, you could probably post pics of what the 88 civic sedan looks like from the same angles. It’s not going to give you a definite answer because it’ll most likely just be a lot of “looks like it should or looks the same.”
with the sedan its the same style muffler. you should be able to fit it but you would actually have to have hangers welded in the correct spot for the sedan as for the hangers for our DAs dont line up.
Im not too sure about the sedans but I know for the ef hatches they line up perfectly, besides the hangers. With that being said, the tip may or may not extend past the bumper. Good luck.
I took some pics of my 1992 GSR muffler installed on my 1988 LX sedan. All I had to do was relocate the hangers. I also put 2 coats of high heat spray flat black paint on it for extra corossian protection.
I’m going to change out the Si tips for GSR tips.
