EDIT: Found the info. thanks again guys
You need to convert to a hydro trans, convert to OBD1, use your axles I believe and you can reuse your SOHC mounts.
GL with the swap I replied to your thread over on H-T.
Mostly right, wrong it’s already obd1, right, wrong.
