92 DA with spark and fuel, but wont start...
its a obd0 b18a1 with obd1 alt, §§§§§ & inj in a 92 integra ls
has spark, its getting fuel and trys to start but only gets to about 4-500 rpm and wont acually kick over
how’s your main relay?
fine, i got fuel coming from the injectors, i pulled the rail off and watched em
i checked spark on the #1 plug, maybe i have a bad plug in #2-4 ill get new plugs tomorrow and try that…
check your timing
Im guessing since you havent pulled the plugs you havent done a compression test?
Is it Trowing a check engine light?
Turn your key to aux position. If the light remains on after your fuel pump stops priming then you have a code Trowing.
