92' GS-R won't go into gear?
It will turn on but won’t go into gear while the car is on. If I put it into gear with the car off and turn it on I can drive in the one gear but can’t change any gears.
To my knowledge, everything is stock but I/H/E.
Do you notice any sounds when pressing the clutch pedal?
sounds like a bad clutch.
Yup x2 ^^
the fingers on the pressure plate could be messed up or the springs on the clutch disk could be jacked. either way, buy a clutch kit. an exedy kit with the pressure plate, clutch disk, throw out and pilot bearing can be had for 150 or less. if you wanna get froggy, you can get a new flywheel too. there is an exedy kit that has all pieces in it for under 200.
I agree, it is a clutch problem, [broken spring(s)]… http://www.bing.com/images/search?q=broken+springs+on+clutch&FORM=HDRSC2#view=detail&id=5867BA32C84871615ED1F847B1D12E9EAB249221&selectedIndex=11 94
