My best friend and I at the Toronto Motorsports Park road course here in Cayuga, Ontario, Canada. With Touge.ca on May 1/2010. It is my first time on a road course so be nice. Plus I was battling VTEC problems and an extremely annoying rattling shifter lol, and we had not set the camber to where we wanted yet, going to this event was a last minute thing so we weren’t fully prepared but it was still loads of fun.
YouTube videos:
Attached pictures are a picture of the map of the course, and our G-force measurements using a mounted iPhone 3GS and Dynolicious.
1.04 lateral G’s
0.91 braking G’s
0.64 acceleration G’s
Other attached pictures are just a couple of my best friend and I on the road course having fun ![]()
MOD LIST:
ENGINE:
-96 JDM B18C engine swap
-Valvoline full synthetic 5w30 oil
-Fram full synthetic oil filter
-NGK Iridium IX spark plugs
-NGK power spark plug wires
-AEM cold air intake
-aFe air filter
-Vibrant Performance intake couplings
-Fram PCV valve
TRANSMISSION:
-96 JDM S80 transmission swap with J4D LSD
-GM Synchromesh Friction Modified transmission fluid
-Hasport cable to hydraulic clutch conversion kit
-Hasport B-series hydraulic transmission mount
-Skunk2 dual bend short shifter
EXHAUST:
-Full Pacesetter exhaust (header & cat back)
-Magnaflow hi-flow catalytic converter
SUSPENSION:
-Tein SuperStreet coilovers
-Skunk2 front camber kit
-SPC rear camber kit
-BLOX Racing rear toe kit
-Energy Suspension bushing kit
-ARP wheel studs
-Megan Racing C-pillar bar
-Rear upper strut bar
-Front upper strut bar
-Mooge front lower ball joints
-Sandblasted and black painted LCA’s, front forks, front spindles, and rear trailing arms
BRAKES:
-EBC slotted and dimpled front rotors
-EBC GreenStuff front pads
-Russell stainless steel front brake lines
-Red painted brake calipers
-DOT4 brake fluid
WHEELS:
-15x6.5 gold Konig Feathers
-205/15/50 Falken Azenzis RT615
-Black lug nuts
-Black tire valve caps
ENGINE MANAGEMENT:
-Chipped P28 USDM ECU
-Main grounds upgraded to 4 gauge wire
EXTERIOR:
-Black housing one piece headlights
-Radio antenna relocated to windshield
-Shaved emblems
INTERIOR:
-90-91 JDM gauges swap
-Red LED lighting swap
-Black with red stiching shift boot
-Mugen replica shift knob
-Momo hub
-RS type steering wheel
WEIGHT REDUCTION:
-removed spare tire & jack
-removed cruise control
AUDIO:
-Sony Xplod stereo deck
