Quick question are these crank pulleys the same ? reason asking i noticed my 92 gsr crank pulley has a chipped on it so i need to change it asap and my buddy has a 94-95 gsr crank pulley and I’m not sure if i should get that and replace it let me know what you guys think thanks …
anyone?
will this crank pulley work?
They are different.
from what I’ve been reading it says their the same and that i can use the crank pulley is this true?
It will work you will need to change the power steering pulley to match
Yes… They are different.
i don’t have power steering or AC will that matter?
Then you are good to go.
thanks
