92 gsr oil light blinking
Everytime i change the oil in my gsr the oil light comes on and blinks, it only does it for a day or 2 then goes away, anybody know what it could be?
try checking the pressure with a gauge in place of the sender
The oil pressure light is controlled by the ICU . If you are sure that you have oil pressure, I would look at the ICU there is info on how to fix it in teg tips on this site
Mines been doing the same thing guys it come on ever so lightly and especially right now during winter? Oil is fine I’ve checked my oil pump the motor is brand spanking new? Any tips? Not B17a1 but also did that when I was running the B17 ? Bad sensor?
I seem to have the typical ICU capacitor issue (i’m guessing). If I don’t drive my car for a few weeks, then the oil light will faintly glow and sometimes the oil light will flash. I ran an oil pressure gauge for several weeks and managed to catch the oil light glowing and flashing, but the oil pressure was well within spec.
Definitely check the pressure. Don’t want to risk loosing the engine on a hunch.
