so just got home les schwab and they said i need to buy a camber kit cause they need to allign my tires cause its eating the inside back tires too much. and i have no idea on what to do. so should i just buy a set of camber kit for front and back and just tell to install it for me and have them allign my car for me or is it an easy fix taht i can do myself.
Well first off this is the wrong forum to post this question
are your rear tires really tilted in? Usually it’s not camber that eats tires but rather toe if you are super low then yeah you’ll prob need a camber kit just to fix the travel but make sure your toe isn’t off alot
well low i bought the car 2 weeks ago and the guy said he just installed some tokico blues and some neuspeed springs or something and i went to les schwab today cause i got those free check up and stuff and the dude told me that i need to have a camber kit for them to allign it. No my car is not super slammed.
Whatever you do,don’t buy the kits from les schwab nor have them put them on without bringing some type of lube for you’re ass. Your best bet is to go to another shop for that. I had les schwab do my kit and i also got the kits from them and they RAPED the fuck out of my wallet.
well yeah to do any camber adjustment on the rear you need a camber kit cause there is no stock adjustment if its not really low you can probably get away with doing the washer trick in the teg tips, or just order yourself a rear camber kit and throw it on yourself its super easy just 3 bolts to remove swap the new part in and replace the 3 bolts, don’t pay a shop to do it, then just have it aligned.
man so all in all im looking at spenging about 1400 on this, im wondering if i can get this parts online and maybe get a better deal on them?
i was also wondering wheres the camber kit part on the whole thing?
im a noob with this kind of stuff… lol
DO NOT goto Schwabs for that… absolute waste of money.
First, as previously stated, improper toe alignment is whats trashes tires. As long as you rotate them regularly you should be fine with tire wear. Second, DO NOT buy their “camber kits”. They are garbage. Spend $80ish on an Ingalls kit and install yourself THEN get an alignment from Schwabs. They’re adjustable ball joints?? Dont even bother… From what im reading, you’re only dropped MAYBE 2"… no need for that crap… Honestly, no need for a camber kit but still…
The ONLY and I repeat ONLY reason i’d goto Schwabs anymore is for a battery, maybe… I’ll look around for other shops before them, theyre in it for the $$$ and thats it.
Even tires… gets quotes online, search around and you’ll spend less on them even with shipping.
Mkay so new updates i’m orderin skunk 2 camber kit sometime this week and install it myself. Prolly not gonna get new tires till next month. I’m gonna get it alligned tho by Les schwab so yeah.
are you just getting rear camber kits? the skunk2 front ones aren’t made for the DA they will work but will add caster which is fine, from what i heard about L.S. they will probably try to sell you something for the caster too haha. but yeah honestly if your not dropped that much heres what i’d do:
go to napa or a hardware store get yourself like 8 washers and put 2 on each of your bolts mounting the rear upper control arms to the body, this will most likely get you into factory camber specs.
next order your tires online, for $81 you can get a much better tire, the fact that they are charging you 4.25 just for a valve stem shows you they are nickel and dimming you i just paid $2 for valvestems when i got my tires done,
not sure what size your wheels are, or what size tire you want so heres a couple i found on tirerack.com
get the road hazard for $9 so if you hit a pot hole or whatever you get the tire replaced for free
so theres some examples they are still gonna charge you to mount and balance but thats a charge you were going to pay anyway, when they do your alignment post up the measurements they give you and we can go from there,
mine is -1.05 or something in the front and -1.8 or so in the back which is just out of tolerance and more than acceptable for me.
Get your camber specs on paper BEFORE you spend money on potentially useless camber kits if you don’t need them don’t buy them it will save you some money.
