Hey everybody, new to the site and wanted to introduce myself and my car. I’m located in the center of the US outside of Springfield, MO and purchased my first DA9 Integra just a few months ago. The car was going down hill, but was in good enough shape to save. I’m nowhere near finished but I’m at a point now where I don’t mind sharing. Biggest reason for joining up is to read up on these cars and learn all the in’s and out’s. I’ve named my car LSVTEG because it does have a B1/A2 LSVTEC swap with ITR trans under the hood. It currently has around 950 miles on it since the build and going strong. Once I hit 1500 I’ll switch over to my normal oil brand and change intervals.
But anywho… Here is a mod list and some pictures of the current state of the car, like I said lots to do still. But she’s coming along ![]()
Modification List:
B18B1 Short Block
ARP Rod Studs
ACL Tri-Metal Race Bearings
ARP Head Studs
Cometic 81mm MLS Head Gasket
B16A2 Cylinder Head
GSR Camshafts
Skunk2 Pro Intake Manifold
B16A2 Throttle Body
Thermal Plastic Intake Manifold Gasket
Extended Intake Manifold & Header Stud Kit
B16A2 OBD2 Distributor w/ OBD2 to OBD1 Conversion Harness
DC Ceramic Coated 4-2-1 Header
Tanabe Medallion Touring Cat-Back Exhaust System
Innovative 75a Steel Motor Mounts
Innovative Traction Bar Setup
Innovative Shift Linkage
StreetRay’s Billet Aluminum Shifter Bushings
Ralco Adjustable Shifter
Generic CAI w/ K&N Filter (In fender)
Generic Two Core Aluminum Radiator
J2 Silicone Radiator Hoses
Cusco Adjustable Front Strut Tower Brace Bar
KMotors Fuel Rail
KMotors Adjustable Fuel Pressure Regulator
AEM 320lph Fuel Pump
NRG Short Hub
BRG 2.0 Quick Release
Personal Steering Wheel w/ Horn Button Delete
OEM Double DIN Stereo Block Off
AutoMeter Mechanical Oil Pressure Gauge
AEM X-Series UEGO Wide Band o2
DA9 RS Rear Speaker Deletes
TruHart Street Coilovers
TruHart Front Upper Control Arms w/ Hard Race Bushings
TruHart Rear Toe Kit
TruHart Rear Lower Control Arms
TruHart Rear Chamber Kit
15x7 +35 5Zigen FN01R-C Race Series Wheels
205/50R15 Hankook Ventus V2 Concept2 Tires
Seibon OEM Style Carbon Fiber Hood
Aerocatch Hood Pins
91 Front Bumper w/ Mugen Style Lip
Amber Corner Lenses
Amber Bumper Lenses
“JDM” Yellow Painted Fog Lights
DB2 GSR Rear Wing
LED Headlight Upgrade
Yellow Turn Signal Rear Taillights
Full Interior LED Light Conversion
Tuned on Neptune with DEMON RTP
I think that just about raps it up on the mods so far, I might be missing really small stuff but you all get the idea. Look forward to learning what I can to improve my little car, and to get to know some of you and possibly see who’s local. Take care!
[IMG2=JSON]{“data-align”:“none”,“data-size”:“full”,“src”:“https://image.ibb.co/cAxOCz/39388074_10216449553539678_1511790529271037952_o.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“full”,“src”:“https://image.ibb.co/hkLX5K/37384704_10216228492813298_7078945155734044672_n.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“full”,“src”:“https://image.ibb.co/nGaMze/37378860_10216228495253359_4098943811789520896_n.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“full”,“src”:“https://image.ibb.co/kXGGXz/asdfasdf.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“full”,“src”:“https://image.ibb.co/dBvoee/38532448_10216366837271823_8184216704021168128_o.jpg”}[/IMG2]
