first off i would like to say hello im new to the forum. i have a 92 ls/vtec swapped teg and i have looked on the fourm about idling problems i have cleaned the iac valve, throtle cable is in adjustment but it idles a 2000 to 2400 from the time i start it. i saw something about cruise control vacuum leak my curise has been taken off and i can find an lines where do they run to? anything else i should check because it is annoying sitting at a light and the car idling that high.
Welcome to G2ic… there is plenty of info here so you’ve definitely stumbled onto a great resource.
As far as your idle issue… hmmm. Is this something that has just happened out of the blue, or is it a new problem with a recent swap?
If its a new problem I would assume it is a sensor or vacuum leak. I’m betting on a sensor because a leak would make your idle surge up and down. Possibly the TPS is out of calibration.
If it is a problem with a recent swap… What ecu are you running on, since this is a hybrid motor and all, the ecu could be the source of the problem.
i dont know how new the swap is i just got the car the swap was in it. it has a chipped p28 ecu in it. the idle will surge if you start coming to stop it surges a couple of times then goes to 2200 and idles there.
I had this probleme when I got my swap in, I looked around the intake manifold and found 3 nipples that were open or dissconected. I just bought some tubes and reconnected them and my idle droped a lil under 800 rpm’s so I just opened the throttle a lil and adjusted it to 1k…
the fittings I found was in the back of the manifold and in front next to the fule pressure regulatore and last was a fitting ontop of the throttle body.
[QUOTE=da6xsi06;2172294]I had this probleme when I got my swap in, I looked around the intake manifold and found 3 nipples that were open or dissconected. I just bought some tubes and reconnected them and my idle droped a lil under 800 rpm’s so I just opened the throttle a lil and adjusted it to 1k…
the fittings I found was in the back of the manifold and in front next to the fule pressure regulatore and last was a fitting ontop of the throttle body.[/QUOTE]
You know the stock idle is 750rpm… Though raising it to 1k wouldn’t hurt, 800rpm is perfect.
