Ok so i just got done doing a wire tuck in my 93 ls. This car is my project car. I pulled the motor out of my dd it ran complity fine in the dd with no cel. Now that the motor is in the project car it wont rev passed 3500. I have a cel on check the code i believe i have a 7, 10, 17 and 43. i guess after doing about 2 hours of reseach i give up. I just need some to point me in the direction to find wat do the codes mean.
Ok correction i have code 7, 10 and 16.
7 is tps
10 is intake air temp
And 16 is Fuel injector
Please correct me if i am wrong
I know i checked the wireing to the tps it all checks out. i took the tps off the throttle and it fell apart in my hand. I replaced with that i think is a good one.
The intake air i had to replace the Plug so i thoughti wired it wrong. A chart to tell me wat the omhs should be at this temp.
And fuel injector i have a lose wire to the ecu that will be fix today.
I guess all i am looking for is a description on the 3 wires to the tps and same with the iat sensor with a charts. I used Mitchell but it suck for oldered cars.
Ok i figured it out i fix the lose wire for the injector at the ecu and it fixed the rpm problem the tp code went away, and th iap senor code is still up i think i got the wires flip. But i had to get the brakes done ill mess with it tomorrow. I took for a rip down to the gas station and she seems to run like a champ
