94 integra ls distributer on a 90 wiring harness
Is it possible to swith the wiring harness on the two and it work?
i swaped 94 teg motor (b18b1) in to my 90 integra i have been using the 90 distributer and it worked fine but the distributer locked up today. And im kinda low on cash i have the 94 distributer that came with the motor. I was gonna see if this is possible. They have the same amount of wires on both of them same colors too. does anyone know if this possible.
Thanks,
Tafadzwa
no, they are too different. in order to use the obd1 distributor you’d need to use an obd1 ecu…to do that you’d need to do a LOT of rewiring or get a jumper harness.
just find another obd0 distributor, it’ll be cheaper and easier.
