97 EX civic side skirts???
hmmm i just bought EK civic sedan skirts !!
was just about to attempt to put them on but this thread says that all these guys used hatch/coupe skirts
anyone know if they are the same before i start cuttin into it ???
if anyone can get some close up pics of the first car and how it was mounted it would be greatly appreciated !!
one more pic
so by the looks of it … it doesnt sit in the door
it sits slightly below it ?!?
yes sir
so where did you actually make the cuts at?
thats a secret ;D lol nah on the umm u see the top part of the skirt that lines up to the body of car it starts narrow to thick all the way down to the back of the skirt n back to narrow
something like
^ like that u gotta cut the thick part so its all even out to the narrow side
(sorry if u got confused its sorta the best way i cn explain without showin pics)
what about the from the back or the front, since they are a little longer?
i cut the front cause i like the little design in the rear
would this fit a db? 4dr?
yes they would. same precedure aplies. cutting triming etc, it might need different measurements tho. i have a db1 and im gonna try it my self
now for a db1, would the coupe or hatch skirts work? or do i have to get a sedan civic skirts?
you can check out mine in this thread here
http://www.g2ic.com/forums/showthread.php?t=135997
i did them just last week and they turned out excellent…
but twizo… u said u cut it at different widths… thicker in the middle ? (by the looks of it in the pics)
i can mine the same all the way across and they turned out fine.
yeah i meant to say the skirts oem come thicker in the middle so u have to cut the same all the way acros is what i was trying to say
so do they get bolted on from front and back or do they have to be molded. . .
Yeah, once you get them all trimmed how and where do you bolt them to the car?
Does anyone know how these skirts are mounted to the car?
well since i cut the front i drilled screws in the rear n bottom parts of it make sure to align it while drillin it so it doesnt touch with the door…
On the under side of our cars there is a lip or seam that stick out, did you mount your skirts over that lip, or cut them so the skirt would rest against it?
dc sides
i know this is from a while back but u still got them skirts TWIZO???
i want to know how this mounts up and where to cut!!!
