someone gave a set of new trailing arm bushings for a 98 civic will the fit my 91 teg!
yes but you have to use the old da ring. if you take it apart you will see what im talking about. also, search for “trailing arm bushings” there is a few whole threads about this. i think its trailing arm bushings development or something like that. there is a lot of info about the bushings in general on honda-tech. honestly u r a lot better off using a stock rubber bushing than a es poly replacement. good luck to you.
Thanks
take a look at the orijin spherical bearing thread i started this week. archon posted a great thread about exactly how to perform the process. hope that helps.
