98 gsr cluster swap under way
got a piture of the gauge cluster but i have to take more when the miss comes over but heres a teaser
well i jus finished the wiring diagram and ill post it when i splice it all tomorrow and see if everything is ok:D
Gj man,…
the hard part is molding it into ur cluster right?
take ALOT of pictures:)
late
what are u going to do about the speed sensor?
the speed sensor was easy i just hooked it into my 94gsr tranny im started taking pics today
i jus finished the wiring diagram and im posting it tomorrow:)
as for the cluster it was not bad at all it was easier then i thought it would be
you have a hydro tranny?
i swapped the hydro with my cable
update?
oh yeah and :gotpics:
Yeah I’d like to keep posted on the updates as well. Especially the Cable to Hydro conversion.
got the wiring diagram done yet? Could you email any info you have? sgrunder@amdevcomm.com I am in the process of collecting all the parts to get this done. And researching all the wiring I need to do.
Thanks,
Steven
alright fellow g2ics i finally got the wiring done and everything runs fine heres what goes to what from a 98 gsr harness to a 92 ls harness
98 Gsr 16 pin 12 pin wires into 92 LS
1.charge-blk/yel 1.charge-blk/yel
1A.charge2-Wht/blu 1A.charge2-Wht/Blu
2.Right trn sig-Grn/Yel (10 pin) conn2.right turn sig-Grn/Yel
2.A Left trn sig-Grn/Blu (12 pin) conn2A.Left trn sig-Grn/Blu
3.High beam ind-Red/grn 3.high beam ind-Red/Blu
4.Dr open ind-Lt Grn/red 4.dr open ind-Grn/Red
5.Hatch opn ind-Grn (10 pin) 5.hatch opn ind-Grn/Blk
(13 pin) 6.Cruise con ind-Red/blu (7 pin) 6.cruise con ind-Red
(16 pin) 7.ilumanation-red/blk (10 pin) 7.ilumanation-Red
7A.ilumanation-Red (10 pin) 7A.ilumanation-Red/Blk
(10 pin) 8.Low fuel ind-Blu/wht (10 pin) 8.Low fuel ind-Grn/Red
(13 pin) 8A.Low fuel ind-yel (12 pin) 8A. Low fuel ind-Yel
9.Selt belt remin-Red/Blue (10 pin) 9.Selt belt remin-red/blu (13 pin) 10.Check eng lgt-Grn/Org (12 pin)10.C.E.Lgt. Grn-Org
11.Low oil psi-yel/red 11.Low oil psi-Yel/Red
(16 pin) 12.Brake lgt-Grn/red (10 pin)12.Brake lgt-Grn/Red
(13 pin) 13.Fuel gauge Grd- blk (7 pin) 13.Fuel gauge Grd-Blk
(16 pin) 13A.Fuel gauge pwr-Yel/Wht(10 pin)13A. F.G.Pwr-Yel-Wht
(16 pin)14.Vehicle Speed sensor-orange
(13 pin) 15.Tachometer-Blu (12 pin)Tachometer-Blu
16.Engine cool gauge-Yel/Grn 16.Rngine cool gauge-Yel/Grn
pics are coming in a few days:up:
:bow:
take pics of the engine bay also, i want to see how u swapped the transmission, i might do the same thing. Thanks.
You don’t have to swap the tranny to do the gauge cluster swap. You just need the VSS sensor off of a tranny (not sure if different models are different) that has the electronic speedo.
I know that but I want to make my clutch system hydro.
is that even possible?:shrug:
good job on the wiring!:slight_smile:
yeah he’s done it and zoomintegra also
